aftermarket ecu
Seight-V8
aftermarket ecu
Post by Seight-V8 »
hiya all,
Just playing around with a few ideas on the aftermarket ecu to run my newly built engine.
What would i need to do to convert a GEMS efi engine to a VEMS ecu?
Could i use all the standard sensors and coil pack?
Hoping this would be possibly be a good solution, as i orginally planned to run the GEMS in my westfield, but its just to expensive/complicated to sort out.
scott
dnb
Post by dnb »
All standard sensors on the GEMS v8 should work with VEMS. The coils also work. You can remove the airflow sensor since it isn't needed.
You will need to add a wideband lambda sensor because I think GEMS uses narrowband (I could be wrong here) and an air temperature sensor.
