ARP flywheel torque
Posted: Sun Feb 15, 2009 10:26 am
by Coops
Any one know the torque settings for ARP flywheel bolts????
is it the stock rv8 bolt settings?
Posted: Sun Feb 15, 2009 12:19 pm
by matchmetisse
got them bolts then mate
Posted: Sun Feb 15, 2009 6:35 pm
by Coops
yes mate found the flywheel bolts,
still trying to find some bolts for the alternator bracket
Posted: Mon Aug 24, 2009 9:29 am
by topcatcustom
What did you do them up to in the end Tony? I have ARP's too and want to put the flywheel on soon...
Posted: Mon Aug 24, 2009 3:07 pm
by ged
I'd say use the stock settings of 60 lbs/ft.
Posted: Mon Aug 24, 2009 3:42 pm
by Coops
thats what we did Ged in the end i think
Posted: Mon Aug 31, 2009 7:23 pm
by adamnreeves
ARP flywheel bolts with ARP moly assembly lubircant 62 Ft/lbs. You not too far out however if you did not use the arp moly lubricant they recommend then it makes a difference, they do give different torque figures for different grades of oil as well!
Posted: Mon Aug 31, 2009 9:18 pm
60/70 will hardly make much odds. They're a big bolt.
Wonder what the torque spec is with thread lock then lol
Posted: Mon Aug 31, 2009 11:11 pm
by adamnreeves
Do not use thread lock with ARPs.
stevieturbo wrote:60/70 will hardly make much odds. They're a big bolt.
Posted: Tue Sep 01, 2009 6:41 pm
adamnreeves wrote:Do not use thread lock with ARPs.
That makes no sense. Some arrangements dictate that a thread lock or sealant must be used...such as the LSx platform, as the bolt holes go right through to the crankcase void.
And Ive used thread lock many times. It just says to torque to spec before it dries.
Posted: Wed Sep 02, 2009 12:55 pm
by adamnreeves
I meant ARPs for flywheel. The flywheel bolts are captive and thread lock should not be used in this application.
Anyway I am lead to believe that if a fastner is torqued up correctly then you do not need theadlock. what did they do in the days before it. I know it is a safety net.
stevieturbo wrote:adamnreeves wrote:Do not use thread lock with ARPs.
