Apart from my interest in Range rovers and v8's I also have an obsession for Porsche 911's.
I've been meaning to ask this question for a while so here goes,
whilst setting the preload on the rover valves why not use an alternative method suggested for 911 engines which usually get done in a similarly fiddly method as we use on the v8?
If someone could work out the rocker ratio you could then just use feeler gauges straight of the top of the valve using the same go/nogo method that you would with the go/nogo wire method in the lop of the lifter?
I'm not sure if I've explained very well so have a link to a thread in a Porsche forum that I use a lot.
I would guess that others may have suggested this method before, am I missing something here?
check out the link there is a picture on post 10 and a good description on post 8 by 2.7Racer
http://forums.pelicanparts.com/showthre ... adjustment
What do you think??
STEVE
Oops forgot to paste the link
