S U Carbs Leaking
Posted: Sat Jan 13, 2007 12:41 pm
A friend (yes, really
) has an SD!-derived 3.5 RV8 in his Cobra. After only a few hundred miles he decided to do something about the blue smoke so stripped the engine. Bores were scored necessitating a rebore, new pistons & rings, new cam bearings etc. Engine now rebuilt with Viper (or Hurricane, I'm not sure) cam installed. He has SU carbs on the original Rover manifold.
Before the car was SVA'd he had difficulty starting - found that the sump was full of petrol
so carbs were stripped and the opportunity taken to put in the correct jets etc. Float levels were set by a man who knows what he's doing. After that the car ran, was driveable with reasonable power but the blue smoke problem eventually got worse.
Obviously the scored bores led to conclusion that the carbs may still be leaking fuel - bench testing (carbs fitted to the manifold) reveals that the fuel does indeed go straight through. I have suggested that he test each carb separately to see if one or both are at fault. he did say that petrol was coming out of both sides of the manifold
My thought is that there is relatively little to go wrong on these carbs and that the problem is with the floats. he also thinks possibly damage to the (new) jets or seats.
Any advice/thoughts?
