hiya all,
Is it usual for the rocker shafts to bend during use???
I know mine where knackered but..didnt expect them to be bent upto about 3mm over the length.
Also the rocker pedastals are no longer round where the shaft goes...i recon about 0.50mm out of round.
anyone have exprience of this.
Shall i use the pedastals or gets some new ones.
scott
rocker pedastals & shafts
- Seight-V8
At a guess I would say something bad has happened in the past. The shafts can flex slightly but personally I have never seen them bend without a major incident. I would get new pedestals as well or at least good second hand ones. Your in an area of the engine where a slight change in size can make a fair difference because of the lever action
They sound knackered to me
I would look at the threads in the heads where the pedistals bolted down. To do all that to the shafts must have put some loads into the head castings. That is if someone didn't just put them on the floor and trod on them during a previous rebuild.
- Seight-V8
