Ticking on acceleration?
My 1993 Disco 3.5 is making an infuriating "tick tick tick" under acceleration to about 25mph. Its seems to quiet down but this takes a good 10 mins and doesn't completely go. Otherwise its running very well.
Does this indicate a cracked exhaust manifold or lifters?
Any cheap tricks to quiet either down?
Cheers!
I know this has probably been asked before, I did search!
Cheers!
I would opt for exhaust manifold / gasket probs first.
ramon alban
Grant, I agree with mgbv8, a probable cause is a small exhaust gasket leak thet reduces with heat expansion of the metal thereabouts.
It may not even need a replacement part, just tighten up all the exhaust manifold bolts to their correct torque to see if it can be attenuated.
If it is a leak as suggested, you ought to be able to hear which side of the engine its coming from.
And if it does turn out to be thus, but cant be stopped, fit new gaskets.
Have a good look with a torch for any signs of soot marks around the EX flange gaskets Grant.
As Ramon says, run a socket around them first all to make sure they are nipped up ok.
Hi again, its definitely on the drivers side... the rocker cover has a few slight leaks which has left black stains around the manifold! Will give the bolts a tighten and see what happens, cheers!
Changing the tappets looks pretty simple from the haynes manual (basically remove inlet manifold and pull them out?) but the full whack cam/chain- not sure about doing that myself
Grant
You have to remove the rockers as well. And remove the pushrods to get the lifters out. Then you have to check / set tappet pre loads before rebuilding. Not recommended to fit new lifters to a worn cam though. They may not last too long.
Grant
The rocker shafts tend to wear on the underside. Mind you, if you had a shaft that was worn bad enough to make a noise it would be obvious as there would be a huge recess.
Hiya, the push rods all move up and down smoothly except one which flops around and feel disconnected at the bottom- is this a sign of a bad lifter?
No compression test but no other usual hgf signs (overheating/mayo/coolant loss/steam etc).
Its difficult to describe the ticking, now I've listened more closely its there at idle as well, the tick just isn't as pronounced if that makes any sense!
