what's the difference
K4000JB
Post by K4000JB »
hi guys just wondering if anyone knows if there is any differences between the flapper injectors and the hotwire ones ,apart from the different fittings , e.g. coil resistances, flow rates, flow patterns?
ant
just about everything is different. The end that goes in the manifold is a different size. Flapper injectors are low impedance where hotwire are high impedance and the flapper injectors don't flow as much as 3.9 hotwire ones. Basically they aren't interchangeable at all.
chodjinn
Post by chodjinn »
Walk away from the Flapper, walk away from the Flapper . . . !!!!
K4000JB
Post by K4000JB »
thanks for the replies i only ask because i was going to try something a bit different. you have answered my questions i thank you :nw
K4000JB
Post by K4000JB »
sorry to bring this back to the top
can anyone tell me at what pressure the flapper injectors run, what type of spray pattern they deliver and what is the maximum flow rate
thanks in advance
They run at 35psi at full throttle.
Not sure about the other two questions.
