Camshaft choice
Camshaft choice
I'm going to rebuild the 4.6 RV8 in my Landie, to freshen it up, and convert it to MegaJolt. It'll also get a pair of 2" SU's.and a spot of porting. Also I'm going to fit the 4.0 pistons to raise the CR a bit. It runs an auto transmission.
Whilst I'm at it, I fancy a new camshaft. At the moment it's got an RPi Torquemax, which pulls like a train, but I want more!
There seems to be plenty of choice, e.g.:
V8Dev Stealth
RPi Optimax or Piper 270 or Piper 285
RealSteel have various Viper ones.
Any recommendations? Is there anywhere that has a set of dyno graphs showing comparisons?
V8Dev Stealth
Teesdale_landrover
- Helpful or Confused
poo slinger
Chris,
2" SU's can be lightly modified to flow enough for up to 280BHP Vizard details the mods in one of his books. although I suspect you would need to get the manifold runners opened up to suit the 4.6 engine.
Re the 4.0 pistons I think you will find they will up the compression to approx 11.8/1 which may be a little high, do check as I am only going from memory.
Just found some data 4.0 pistons have a bowl of 13cc.
4.6 pistons have a bowl of 22cc. and that confirms the 11.8/1 figure.
Back on topic!
I've got a piper 285 (stealth max) from RPI in my 4.6, it goes very well!
I run standard spec (from RPI) lifters and a piper vernier timing set.
Pete
Pete
Piper 285 - does that require piston cutouts?
Bodger - The carbs are complete, so theoretically it does run on petrol, but there's some issue that I've never bothered to fix.
Kevin - As it runs on LPG 99.99% of the time, the nice high compression should be OK. And for the occasion I do run it on petrol, hopefully I can use the Megajolt to make it tolerable.......
Pooslinger - Not sure if the Torquemax goes in a 3.9, but when I take it out next week I'll number the cam followers so they can be matched back to the cam. PM me an offer if you think it's going to be OK for you.
Any other opinions other than a Piper 285?
poo slinger
ChrisJC wrote:Piper 285 - does that require piston cutouts?
My pistons are cut out but whether its required or not I don't know! RPI could tell you what's required.
Paul at V8 Tuner reckons that I could have gone for something a bit hotter as my car is a toy more than anything. (cob rep) Anyway it pulls top from 1500 rpm round to 6k and is "f-in" mental so I'm happy with it!(Loads of other stuff done to it to
Pete
landrovernuts
Interesting to read this thread, I would have thought a piper 285 was a bit peaky for a landy, I would stick to something with a flatter torque curve. Having said that I have a Kent 218 in a 4.2 in a landy and this does not seem to suffer low down torque loss at low speed and am interested to hear any comments on what a Piper 285 is really like in a heavy car with the aerodyamics of a brick. From memory it does not need cut outs in the pistons.
For a short while I ran 2" SU carbs on my 4.2 and have to say apart from the lack of choke performed really well. My engine has a few other modifications however managed a respectful 247bhp with this carb set up. would have stayed with them if I hadn't got a hotwire set up.
Toby
Toby
Assumably that output was with modded heads if so what is the spec?landrovernuts wrote:Interesting to read this thread, I would have thought a piper 285 was a bit peaky for a landy, I would stick to something with a flatter torque curve. Having said that I have a Kent 218 in a 4.2 in a landy and this does not seem to suffer low down torque loss at low speed and am interested to hear any comments on what a Piper 285 is really like in a heavy car with the aerodyamics of a brick. From memory it does not need cut outs in the pistons.
Toby
landrovernuts
V8 Devlopment stage 3 big valve heads, block machined to raise compression to 9.75 to 1, pistons machined with valve cut outs, bottom end balanced, Kent 218 camshaft and fitted with Janspesd manifolds and exhaust which has since been binned in favour of EFI ported manifolds (Much better). The engine was intially built by V8D with hotwire injection with bigger ram pipes, gas flowed and ported inlet manifold and 72 mm throttle, Dakar exhaust manifolds and down pipes - it produced even more power then!
Toby
Toby
This may proove of interest.
http://www.pistonheads.com/gassing/topi ... 20profiles
Stealth comes ot well as does the real steel typhoon which seems to be a copy of the Crower 50232.
All subject of course to being properly matched to heads, induction, exhaust and ignition systems.
Kevin
Kevin
