found this site interesting
Posted: Sat Nov 01, 2008 5:29 pm
by ian.stewart
Just wondering about friction weldingm and found a similar question on the NSRA site asking a similar question,
http://www.drivelink.com/quality_re_eng ... rocess.cfm
obviously they put a lot of faith in it!!!
Posted: Sat Nov 01, 2008 5:43 pm
by Ian Anderson
You'll have had bits on your car done this way for years
The valves and stems will be friction welded together for one!
Posted: Sat Nov 01, 2008 9:09 pm
by ian.stewart
Most valves are friction welded, Im using 1 piece valves, I was more intrested in the fact they can friction weld shafts, I was wondering it this is an alternative to re splining??
Posted: Sun Nov 02, 2008 8:43 am
that is how loco axels are welded together, you don't hear of those failing at the weld. I would think it ideal for a drive shaft, but it is a specialised process.
Posted: Sun Nov 02, 2008 3:27 pm
by julian.jay
Fostek Engineering can do this to shorten half shafts instead of re cutting the splines BUT they need a straight shaft to work on as of course it spins very fast. I wanted them to do some work for me but my shafts were not true. Julian
