Crane hi-Rev Lifters.
Just for information really, I 've just ordered up a chrome moly push
rod kit AZ500 from real steel and as I.'m using the crane hi-rev lifters was informed that they have a different cup size to the standard Rover lifters.
The Crane are 5/32" Chevy size and the Rover ones are 3/16" so are 1/32" larger and won't seat in the lifters properly, annoying as I had to buy another half set of rod ends in the right size.
do you know if the cup size on rhoads lifters are the same?
as im running crane lifters now with a set of RS molly P-rods,
and when i get the new crower cam im trying out a set of rhoads lifters this time,
Tony,
I don't know if the Rhoads require a different ball size so be best to check, John at Real Steel is very helpful and checked out the Crane ones to be certain.
Which Crower cam are you going to use? I've fitted a Crower 50232 to the new 4.35 and look forward to how it performs. You probably know but Paul at V8 Tuner usually has some good deals on Crowers.
im running a crower 50233 from Paul,
and yeah i know the deals he can do on cams, as thats where im getting the next 50233, may even try the 50234 this time, depends how brave i feel
- topcatcustom
Yes they are the ones that Crane specify for the Rover engine Part No. 99284-16 but require a pushrod with a the lifter end of 5/32" to fit the lifter.
This would have caught me out if John at Real Steel hadn't told me. I shall be fitting them at the end of the week and if he's got it wrong there's going to be a lot od swearing!
- topcatcustom
If you have the Crane lifters you will still have the same problem, it's the size of the cup in the Crane lifter thats smaller than the rover one.topcatproduction wrote:hmm cheeky, I nearly ordered a set just yesterday but may run over the maths again now!!! So may as well go to adjustable rods...
- topcatcustom
Boosted LS1
Boosted
Have not got and old set and they might not be compatable anyway, the extra cost of a set of correct size ball ends is only £24.00 and I just want to get the engine properly completed.
Just as an aside my engine builder used to grind cams for one of the well known cam grinders in the UK, apparently they used to state that they hand selected lifters to match and what actually happened was they picked them out of a bucket!
Topcat,
Wouldn't have thought it was worth the hassle even if you could polish them down perfectly round, Don't forget they are pretty hard.
Kevin
Topcat,
Kevin
- topcatcustom
It won't make any difference, any Rover type pushrods adjustable or fixed length will have the larger ball end so wont fit the Crane lifters properly.topcatproduction wrote:Was meaning so I didnt have to buy adjustable pushrods! As HD rods are about £35 and adjustable ones are more like £140! They cant be as strong as the HD ones either...
Kevin
- topcatcustom
