3.5i/3.9i Cast Manifolds
Posted: Wed May 07, 2008 4:48 pm
by TVRTASMIN
Was thinking of using two of the right hand cast manifolds (HRC1583) on my P6, as i don't have room for fitting the left hand manifold.
Anybody used this configuration? Should be better than the standard 4-1, as i'm after torque rather than top end power.
Anybody any thoughts?
Posted: Wed May 07, 2008 7:51 pm
Presumably you mean two 'starter motor side' manifolds? If you mean two 'non-starter motor' side manifolds, I think it will foul on the starter.
Not sure what it would do to power, and of course you'd have to make up the downpipes.
Posted: Wed May 07, 2008 9:36 pm
by TVRTASMIN
The two manifolds i aim to use are the shorter of the normal pair. The one where they exit straight down rather than swept back.
I wouldn't have thought i would have clearance issues with the starter though.
I appreciate having to fabricate downpipes, but i was considering using the Range Rover items modified slightly.
Posted: Wed May 07, 2008 10:52 pm
by katanaman
I take it your on about 4x4 manifolds 4 into 2 into 1? you shouldn't have any problems although they aren't the greatest power wise.
Posted: Thu May 08, 2008 6:54 am
by TVRTASMIN
Correct.
I know tubular manifolds would be better for power, but having had a Range Rover and TVR with tubular manifolds, i would prefer to have a little less under bonnet noise.
I'm sure the Rangy 4-2-1 should be better than the standard P6 4-1 log.
Posted: Thu May 08, 2008 7:23 am
TVRTASMIN wrote:The two manifolds i aim to use are the shorter of the normal pair. The one where they exit straight down rather than swept back.
They should fit fine then - as you're using the starter-side one on both sides.
