X-bolt sequence.
Posted: Fri Apr 04, 2008 12:14 pm
by TVRleigh
Hi do you do the X-bolts 1st then the end caps of the other way.
Also what the correct torques for a large journal X-bolted block.
Leigh
Posted: Fri Apr 04, 2008 6:59 pm
by russell_ram
Here you go sir - official torque process.
Also, you should place a small bead of RTV along the bottom corners of the rear bearing before assembly.
Russ
Posted: Mon Apr 07, 2008 9:59 am
by TVRleigh
Thank you,
but can you post a slightly bigger version.
Leigh
Posted: Mon Apr 07, 2008 7:40 pm
by russell_ram
Better?
Russ
Posted: Mon Apr 21, 2008 4:28 pm
by TVRleigh
Yes thank you.
As I wanted to be able to read the writing.
