I' hopefully about to fit a disc-braked rear axle to my 90, to replace the crappy drum axle that's there now.
I'll need a bias valve otherwise the rear will lock up!
Any ideas about which is a good one to use? I've heard there's a small one that Ford do that I could fit.
I'm talking scrappy budget here not new item, so any ideas on which vehicles I can nick one off would be welcome.
I've no real need for an adjustable one as it's no race car.
Brake bias valves
- The Original Tom
Hi tom,
is your 90 perminant 4 wheel drive with a viscous diff like the range rover? Just if it is then the viscous diff will stop you locking the rear breaks early. never managed anything but 4 wheel lock ups my first range rover even with a ton and a half of unbreaked trailer on it. (couldn't lock up the second one because of the fancy suspension/ break managment system on it!).
- The Original Tom
Hi Tom
Many of the seven kit car replica makers do cheep double master cylinder plus ballance bar pedal set ups that take cheep scrappy sourced master cylinders (robin hood engineering, MK engineering, SSC) should be plenty of room under the bonnet even with a V8 in there. Though the C15 set up sounds a good way to go.
Best of luck
Best of luck
- The Original Tom
To be honest I'm not that worried about having it variable, and changing to a twin master system seems like making a mountain out of a mole-hill especially as my current master is in GWO. Maybe when it fails I'll look at that idea - mainly because I'd like fiddle brakes too
