Injectors for Supercharged v8 Question
r2d2hp
Post by r2d2hp »
Hi Everone
Is anyone using GENUINE BOSCH FUEL INJECTORS 0280156280 470CC Z20LEH from an Astra VXR in there Supercharged V8's.
Seem to be readily available and good price too
Anyone any info on them
regards Reg
Re: Injectors for Supercharged v8 Question
Size for whatever sort of power you hope to make, and a little headroom.
Are those injectors the same impedance as you need ? What are you using for an ecu or control ?
r2d2hp
Post by r2d2hp »
Hi Stevie
Ecu is an emerald. I did email to them but it bounced
Will try calling them again to see if 14.5 will work
I was sizing for 440 rwhp. What do you think
Sizewise they should do ok and they do appear to be high impedance ok from searches. Even if you needed a little more flow you can easily bump up fuel pressure.
Must admit I'd prefer new injectors, but really there's probably no reason second hand OEM ones would not be fine. They rarely give any bother.
A quick google for even VXR injectors...seems to throw up a lot of new options at very low money. I'd wonder if these are genuine or Chinese.....the dangers of the world we live in.
I'd probably sooner buy a set of known second hand OEM injectors before a set of these cheap unknowns.
ASNU could do new whatever you need
Or last set I bought for myself I used these guys
https://finjector.com/eng/injectors_450 ... n_14mm-186
I'm sure I've a couple of sets of Siemens 600cc's lying about, short and long I used to use. Certainly they were fine when I stopped using them, but they'd have been lying about now for several years
