I'm thinking of fitting some Weber IDF or IDA downdraughts on John Eales manifolds on my 5.0 TVR engine. Has anyone fitted these and if so, using the valve cover tops as a datum point, how far above the valve covers are the tops of the carbs. I just want to check I have enough clearance to the bonnet
Thanks in advance...Nige
Downdraughts on a TVR5.0
Re: Downdraughts on a TVR5.0
Go to gt40’s.com
Register there on
Ask the question in the relevant section.
And if no response use the search function on that site and look up cock a doodle doo Townsend he has the set up you are looking at and is a friendly chap
Register there on
