I'm currently rebuilding a Rover V8 SD1 suffix D gearbox. All work is done but I can not find the bearing part number for the main shaft output. It is a classic roller bearing (not split bearing). The metric size is 27,5mm x 55mm X 11mm. This is an imperial bearing. Can someone translate this into an imperial size of does someone has the bearing part number?
thanks
Dirk
SD1 LT77 D bearing number
Re: SD1 LT77 D bearing number
RHP XXLJ27.5
many thanks
Dirk
Dirk
