Oh Poo.
Guess what!!! To get the std B starter to fit onto the adapter plate the whole area around the original starter motor mounts was ground away. I now have a 3.5 block, LT77 box with no starter motor. I could park on a hill.
As I have put a lot of time and money into this motor and box I don't now want to do a frig.
The only part of the unit that is not been replaced is the block.
It would be a good time to replace it and maybe go larger than 3.5.
What do you guys recommend? I am hoping I could buy a block with some history so if anyone has a block that would do I would be very interested.
The kit I have is as follows. I would like to keep most of the new stuff I have bought to keep costs down but I would upgrade if recommended to.
Webber 500 carb, Dual Port JWR manifiold and Mr Gasket 2" filter.
Mallory twin Point dizzy with electronic module. (points removed)
SS Ceramic coated Tubular Block Hugger Exhaust manifolds going into a twin balanced system
New timing chain, sprockets, cam (std), lifters and rocker gear.
9.75:1 pistons
SD1 std heads
Hi volume oil pump
The block is from a 1970 RR.
I would appreciate any recommendations but I would like the motor to have not more than 200bhp and keep as much as possible of the equipment I already have .
