Need some help guys,
Has anyone local to Newbury West Berkshire a manual sd1 flywheel I can borrow for about 15min, to bolt my old clutch to so I can measure the distance from the flywheel face to the clutch fingers when bolted down, or if someone else can measure theres and let me know please,
Its so we can work out the difference between the old clutch and the new twin plate clutch to see if we need to machine the bearing carrier and pivot point to give required clearances/travel,
I would do it myself but my flywheel and new clutch are away being balanced and machined to fit at the moment,
Cheers Tony,
Need some help if possible,
