Help. Pics Needed
Posted: Mon Jan 30, 2017 11:25 am
by need4speed
My Hotwire plenum had a load of cruise-control gubbins that was getting in the way of my intake hose so I removed it all.
Could someone possibly show me some pics of the simplest possible throttle cable setup with least amount of parts?
Thanks.
Posted: Tue Jan 31, 2017 10:17 am
by need4speed
No-one huh
Posted: Tue Jan 31, 2017 1:00 pm
need4speed wrote:No-one huh
Could be that removing the cruise control should leave the throttle working normally? It does on my SD1.
Posted: Tue Jan 31, 2017 4:21 pm
by need4speed
No. On removing the bulky cruise gubbins it also removed the throttle assy as well. It seemed to be 1 unit. That's why I was asking for some pics so I could see if I've done something wrong..
Posted: Wed Feb 01, 2017 12:38 am
Well, bits from an SD1 EFI will fit your plenum. The usual cable from there to the pedal. Or the bits from a hotwire without cruise?
I've not really seen a hotwire cruise. On the SD1 EFI, the cruise motor simply unclips from the throttle lever.
Posted: Wed Feb 01, 2017 7:24 am
by unstable load
DaveEFI wrote:I've not really seen a hotwire cruise. On the SD1 EFI, the cruise motor simply unclips from the throttle lever.
My P38's cruise is the old fashioned bellows and cable set-up with a vacuum pump instead of manifold supply to improve control.
Posted: Wed Feb 01, 2017 9:53 am
Yup - sounds like the Hella system fitted to later SD1.
Posted: Wed Feb 01, 2017 1:12 pm
by JSF55
Imagefuel lines on by john fraser, on Flickr
Imagecut down linkage 1 by john fraser, on Flickr
Do these help any ?
Posted: Thu Feb 02, 2017 1:33 am
by unstable load
About half way down this page, http://www.cowdery.org.uk/miscv8.php is a few pictures of the GEMS manifold, one from an SD1 and the later 4.6 one.
Posted: Tue Feb 07, 2017 12:28 pm
by need4speed
JSF55 wrote:Imagefuel lines on by john fraser, on Flickr
Do these help any ?
John that looks like a nice compact setup compared to mine. Are those standard sd1 parts?
Posted: Tue Feb 07, 2017 4:30 pm
by JSF55
They might have been range/land rover parts if it makes a difference ? but it was just trimmed to suit a few plates added for cable holes, I was running auto and needed a kickdown position too
