Spark Plugs - Megasquirt RV8 4.6
Posted: Mon Jun 06, 2016 12:14 am
by garrycol
I am just about to fire up my new build 4.6 RV8 - will be managed by Megasquirt with ignition by EDIS 8. The engine is not a race engine and will be used in a 4wd.
I am looking fore recommendation for spark plugs - preferably NGK brand as they are the most easily sourced locally. I am not sure whether the LR specified plugs are still relevant with MS and EDIS.
Garry
Posted: Mon Jun 06, 2016 7:55 am
by sidecar
I run a programmable MSD on my stage III 4.6, I also run a 100 BHP NOS shot. I run the car on the road. I just run NGK plugs that are one grade colder than standard. From memory I run the gap at 40 thou.
EDIT...Doh, I should learn to read, I thought that your engine is a race engine! In that case I'm sure that the standard plugs will be fine.
Posted: Mon Jun 06, 2016 8:29 am
I'm using the plugs specified with the EDIS version of the RV8. Note these are resistor types, which are recommended for EDIS. Don't think MS would make a difference to the choice of plugs with EDIS.
Posted: Mon Jun 06, 2016 1:36 pm
by Darkspeed
5's
Posted: Mon Jun 06, 2016 10:42 pm
by SimpleSimon
BPR6ES or BPR6E (grooved electrode)18mm plugs, or you can run 16mm plugs BCPR6ES or BCPR6E gapped at 0.9 /1.1mm or 35/40 Thou will work great with your EDIS 8
Posted: Tue Jun 07, 2016 1:04 am
by garrycol
Thanks to everyone for the information - why the alternative lengths - I would have thought only one was suitable.
Garry
Posted: Wed Jun 08, 2016 10:30 am
by SimpleSimon
garrycol wrote:Thanks to everyone for the information - why the alternative lengths - I would have thought only one was suitable.
Garry
Not length outer body diameter inc hex
Posted: Wed Jun 08, 2016 10:59 am
by garrycol
Ok - thanks
Posted: Wed Jun 08, 2016 1:56 pm
by Eliot
Looking through the notes from a friends edis based griff 500 says BR8ES and also BP6RES
I think he went to the 8's to avoid knock, but i think BP6RES is a good choice.
