My Griff 500 engine has the usual rattle on the over run at about 1800rpm even though i`ve just re built it. The only thing i didnt change were the pistons so presume these are the culprits. Not the end of the world as a lot do it but i`d rather it be quiet.
As per usual it is quiet when cold and the rattle only comes on when up to temp. Research would suggest it is the pin fit in the piston that causes the issue. Probably abnormal expansion rates due to the bottom of the piston being hacked about so much.
It would seem that people fitting new pistons from the like of TVR Power have sorted it. My only concern is Powers pistons are like for like cast jobbies, although i suppose they may be a better quality than what TVR used.
So other than replacing like for like with more hacked about items i was wondering if anyone knew of a proper rod / piston combo that will fit the 90mm throw crank.
TVR 5 litre pistons.
- SimpleSimon
But the 500 displacement piston wise is achieved in a bizarre way by removing way to much skirt out of a 4.2 pistonSuperV8 wrote:what's you end goal for your engine?
Unless your going high boost/nitros/high revs cast pistons should be fine.
Tom
