Im running 3.9 block with Crane fast road cam and 28cc 4.2 heads
Fuel injected Have chipped 45mm intake and 75mm throttle valve.
Currently using NGK BPR6ES
These are not very old but I think a couple are playing up
what spark plugs do you use?
- SimpleSimon
I very much doubt you have a couple of dodgy NGK plugs to be honest in over 28 years in the motor trade exclusively NGK I have only ever known of 2 faulty NGK plugs your spec RV8 wont overwhelm the wide heat range of a 6 quite frankly, I suggest you have a faulty HT lead or some other ign component failing
personally I run BCPR7E these are smaller plugs to suit my small boot BB Chevy HT leads and 7's because I have ahigh CR but probably overkill to be honest but after carrying out a plug chop they look suited to my motor
I have also used Denso when NGK have not been available another recommended plug, and why wouldn't they be they are Japanese also , of course in saying all this previously badly fouled plugs wont always fully recover
new or otherwise
Yeah know what you mean but I have had dodgy NGK plugs in motorbikes over the years yes I know I might have other problem but I have 11bar compression new leads cap distributor. all injectors have pulse at injectors.SimpleSimon wrote:I very much doubt you have a couple of dodgy NGK plugs to be honest in over 28 years in the motor trade exclusively NGK I have only ever known of 2 faulty NGK plugs your spec RV8 wont overwhelm the wide heat range of a 6 quite frankly, I suggest you have a faulty HT lead or some other ign component failingpersonally I run BCPR7E these are smaller plugs to suit my small boot BB Chevy HT leads and 7's because I have nearly 11.1 CR but probably overkill to be honest but after carrying out a plug chop they look suited to my motor
new or otherwise
was going to chane plugs befor I on to having injectors out
- SimpleSimon
