Twin exhausts
Twin exhausts
On an RV8, what are the pros and cons with having two entirely independent exhausts (left bank and right bank) over combining them at some point? Ignoring material costs.
OOOOOOeeerrrrr big can of worms but from my very basic knowledge a balance pipe is required between the two to help the scavange effect that the exhaust pulses create, these help draw them away from the engine and make it breath better. The actual distance that the balkance pipe is from the engine can also effect the engines "breathability" as well.
I am sure there will be many more people with more knowledge than me to come up much more detailed answers
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
"wot ee said, gov'..."Spongo wrote:OOOOOOeeerrrrr big can of worms but from my very basic knowledge a balance pipe is required between the two to help the scavange effect that the exhaust pulses create, these help draw them away from the engine and make it breath better. The actual distance that the balkance pipe is from the engine can also effect the engines "breathability" as well.
I have this point to address on the MG - twin tail pipe exhaust system c/o MGOC/made by Double S in Devon; but has no balance pipe or x-over. And that does not make for a good V8 system. Nor, in fact, is it a very nice sound.
My previous V8's I've always fitted a 1.5-1.75" balance pipe where a x-over is impractical, normally located close to the narrow point of the bellhousing. It must be of a flexible joint/pipe material. Too small/big a pipe dia and the scavenge pulse is either too weak or too strong resluting
in loss of efficiency and ultimately power.
Google search 'v8 exhaust x-over / h pipe', there's a lot of good tech data out there. Also worth reading up on v-twin and 2-stroke engine exhaust systems as both rely of the exhaust frequency to gain/maintain power.
As an aside, I've always had a 'thing' for pulse jets. Have you seen this?
The crazily great Colin Furze
https://www.youtube.com/watch?v=bKHz7wOjb9w
This +1.ChrisJC wrote:I did two separate systems on my Landie for a bit. Very noisy and sounded rubbish. The balance pipe made it sound much better.
Dave, thought it would be good to share some different sounds of exhaust for all.
1. MGB V8 conversion with no balance pipe/x-over with a slightly livelier cam. To me, and it's a personal thing, this is not a good sound at idle and low rpm.
https://www.youtube.com/watch?v=o4mLKE4BQiY
2. MGB V8 with Cherry Bombs - this does sound sooooooooooooo good!
https://www.youtube.com/watch?v=gKVAuwNgoc0
3. Conventional V8 with single sports...it sounds very good
https://www.youtube.com/watch?v=GMPu4ZgXggw
4. And finally, some old codger in a home brewed special...would your bonnet look as good...? And maybe struggle with the neighbours...
https://www.youtube.com/watch?v=dcwxRoOiHac
'Hello Perry...'
There is a not very scientific way of finding out where the balance pipe needs to be, go for a fast blat and see where the exhaust is hottest, that was what I was told many many many years ago. Dont think this was exactly very well constructed as an idea but if it works
I have a balance pipe around the gearbox area, straight across, between the pipes, not ideal but my exhaust goes where I can run it, then there is a kick up the width of the pipe, then straight through oval 18 inch boxes just before the rear axle then the pipes go under the axle to the rear, its not noisy at all, sounds great.
http://m.youtube.com/watch?v=7HKbnheoQGY
Rover 3.9 V8
Full 180 degree cross over
Basically take the middle 2 pipes from each bank and put them into the other side collector
It then pulses alternatively down each pipe
Or sounds like 2 straight 4 engines in perfect unison
Rover 3.9 V8
I was told to give it a spray of aerosol paint and go for a blat. Where the worst burning of the paint stops is where the pipe needs to be.Spongo wrote:There is a not very scientific way of finding out where the balance pipe needs to be, go for a fast blat and see where the exhaust is hottest, that was what I was told many many many years ago. Dont think this was exactly very well constructed as an idea but if it works
Same for tuning a 2-stroke pipe, cut the tailpipe off at the hottest point.
