http://www.compcams.com/Company/CC/cam- ... d=154&sb=2
What you guys think of this cam??? I've got to get a replacement so might aswell get something interesting!! Going to be in a 350 Chevy that's been taken out +30 so works out about 5.8 litre ish, heads are the old cast camel hump hears which have been mildly ported, forged pistons and 4 bolt mains running about 11:1 CR
Jono
opinions on this comp cams grind
It should be a lively combination, probably about right with the heads and for its use. I have a 252 263 mechanical roller in my drag engine with similar lift (.688") but 383 ci, I recon it will give a similar curve up to about 5500 revs as mine. I have bigger heads, a sheet metal manifold and mechanical fuel injection on a bug catcher it picks up with no real fuss and pulls like a thing that pulls very hard I think it should make a fun engine.
best regards
best regards
sounds perfect, I must confess I was wondering how your going to get roller lifters on a tight budget, a very good investment they will probably be worth a good 30 bhp over a flat tappet cam with those heads and in the long run they will save you money if you need a hotter cam in the future as you won't need new tappets with a new cam.
best regards
best regards
Jono FD3
My bad, it was the gearbox that went not the bottom end!!
The engine is going in to a rift truck and is only used on track and weighs in at about 1400kg. Going to be running custom tubular headers, holley 600com double plumper, and not sure on the inlet as yet as I'm still to get one!!
But I should be able to get the cam and lifters for about 240 -250 delivered... How's that sound price wise??
Also another one.... I've seen different size lifters for sale on the bay, is that going to be for old cast blocks, then the lt1 variant and the later one's or are there different sizes you can get for the early blocks? Just want to check as I don't want to lash out the money to find it won't fit my block!
Jono
Jono
Jono FD3
Hi guys, sorry to be pestering all the time!
I've missed out on the cam above as the guy wanted $200 to ship it to the UK which I thought was taking the P a little! But I've just bought some parts of a chevy man and he has got a full retro fit roller cam with uprated push rods, and roller lifters, but not sure if the cam would be a little weak or not?? apparently he pushed 320bhp/lbf from a 383ci block on a dyno day with the engine running like a bag of spanners (does this sound about right?) anyway the cam is tis one: http://www.compcams.com/Company/CC/cam- ... d=304&sb=2
Jono
Jono
