Conrod bolts 4.0 rv8
Been searching and getting different views, do the con rod bolts need to be replaced on the 4.0/4.6 gems rv8 or can they be reused?
Every bolt stretches when it is tightened up. The question is how much and if it goes past it's elastic yield point.
Just because a bolt is torqued to angle doesn't automatically mean the are tightened past their yield point. Torque the bolt by an angle is generally more accurate because your mostly taking out the variable of friction.
I have re-used con-rod bolts on several engines with no concerns.
