Help please firing problems not firing 2 on each bank
nige71
Post by nige71 »
Hi All
Just started my land rover series 2a v8 up and is not firing on
2 and 8 on right bank
3 and 5 on left bank
range rover classic 3.5 engine 1986 on (su carbs)
any info would be great Thanks Nige
harvey
Re: Help please firing problems not firing 2 on each bank
Post by harvey »
nige71 wrote:Hi All
3 and 5 on right bank
I assume you mean 3 & 5 on the left bank, and if that's the case, and as you're running twin SU's then all those cylinders are fed by the O/S (RH) carb.
nige71
Post by nige71 »
sorry yes left bank do you know the best way to go about sorting this out.
Thanks Nige
Check the operation of the duff carb - does it have a petrol feed?, does the float chamber / bowl (whatever they have!) work?, is the linkage present and operating? Needle missing?, diaphragm split?
nige71
Post by nige71 »
Hi Chris
I put refurb kits in both carbs 8 mouths ago but due to lack of use
something may have stuck will remove carb tomorrow and check
thanks for info.
Nige
Could well be stuck float bowl needle, so no petrol on that side.
nige71
Post by nige71 »
Thanks All for the info it was the float needle stuck now all ok.
Thanks Nige :D
:D
Chris
