which wideband should i buy
chris-stockton
- Helpful or Confused
ok guys, after a pretty crap rr session yesterday, I think the best way forward is going to be to buy a wideband & controller to get my westy set up correctly. It has a weber 500 on it at the mo but from what i saw yesterday is going to take quite a bit of experimenting with different jets/metering rods to get it to run well, something Im not prepared to pay somebody hundreds of pounts to do after wasting money yesterday.
So I've a few questions:
1) I am assuming the most suitable place to mount the boss's for the probe would be at the point the exhaust branches from 4 into 1.
2) what is the best value for money kit?
3) Id also like to be able to log the data with the kit, with the performance on WOT there is no way I would be able to keep an eye on the gauge.
4) What kind of a/f ratios should I be aiming for on cruise, light acceleration and WOT
93 tvr chimaera 430
91 westfield 430
91 westfield 430
If you like building things, Tech Edge do a self assembly kit. That's what I have, on the principle that one designed for home assembly means it can likely be repaired if it should go wrong - unlike so many factory made things.
Of course it's much larger than some others - the controller isn't that much smaller than a MegaSquirt.
I dunno much about others - except that there seem to be lots of problems with the LS1. Of course that might just be because they sell more than any other.
I have my O2 sensor mounted where the system goes into one - towards the back of the gearbox on my SD1. Seems to work just fine.
I run an LC1 and a digital AFR gauge, I don't bother logging the info other than writing stuff down on paper!
The LC1 does seem a bit of a pain as you have to actually wire it up to the gauge, I mounted mine gauge in a plastic box, it only run the system when I'm messing about with the carb, I suspect that other systems will work just as well as long as they fulfill your monitoring needs.
With regards to AFR figures then your engine will determine some of this, in other words its no good trying to get the idle figure to a figure that you have been told if the engine does not like that figure. My cam must have a fair bit of overlap because my engine runs best on idle at 12.2:1 AFR which is quite rich, it's no good me trying for say 13:1 as the idle goes rough.
My cruise is around 14.5-15:1, the throttle response goes bad if I run it leaner that that. Other RV8's that I have messed about with which were running the Eddy 500 needed the same cruise figure.
Two figures which are often quoted in books are the acceleration and WOT figures, I believe that most engines will actually want the same figures, Vizard stated this in one of his books. From memory acceleration needs to be around 12-12.5:1 and WOT needs to be 12.8-13:1. The power falls away quickly at WOT if you run leaner than 13:1, it falls away much slower if you run richer than 12.8:1.
With regards to rolling roads the ones that I've tried don't have a clue about these carbs! (I'm not saying that they are all like that). I think that doing this stuff yourself is much more satisfying and quite within the realms of DIY anyway.
Chris!
Why dont you show us the printouts from the dyno
chris-stockton
chris-stockton
chris-stockton
The Tech Edge kit I mentioned can log to a plug in memory card - so you don't need your laptop present just for logging. If course they also do ready built units.
http://wbo2.com/2y/default.htm
Johnny Rotton
I recently purchased an Innovate MTX-L digital AFR gauge for my 4.6 Westfield with Weber 500. Having had a bung welded into the exhaust pipe before the silencer on driver's side and wired up the gauge, I could not get the gauge to calibrate ! Ordered it from Graham Goode Racing and they are sending me another as I write this, so difficult to recommend this one at the moment. Hoping to install the new one at weekend so will let you know if it works.
Have already had a play with the jets and rods based on Sidecar's recommendations, but as he says, the only way to be sure is to check the AFR. I have 83 primaries, 63-47 rods and 86 secondaries, so will be interesting to see what the AFRs are.
If your setup uses the 'LC1' as part of the kit then make sure it is nowhere near the dizzy or the HT coil (or any HT leads). I blew my first LC1 up due to the electromagnic radiation that is given off by this stuff!Johnny Rotton wrote:I recently purchased an Innovate MTX-L digital AFR gauge for my 4.6 Westfield with Weber 500. Having had a bung welded into the exhaust pipe before the silencer on driver's side and wired up the gauge, I could not get the gauge to calibrate ! Ordered it from Graham Goode Racing and they are sending me another as I write this, so difficult to recommend this one at the moment. Hoping to install the new one at weekend so will let you know if it works.
