Where to get V8 MGB engine mounts?
3xpendable
Post by 3xpendable »
Hi All,
It seems to me that V8 engine mounts are varied and also very expensive, I don't fancy paying £90 for the ones below when they look like something I could make myself
But then I've seen different types like the ones below that look similar to my P6 engine mounts (can I use them?)
So the question is where is the best place to get the mounts (new or 2nd hand) and the best place to get rubbers (new obviously) OR does anyone have the dimensions needed that I can make a set myself? Many thanks
1971 MGB GT (V8 project)
chodjinn
Post by chodjinn »
I've had both sets, the second pic are cast aluminium ones that I think I got for £50 new, from the likes of V8 Conversions I believe. Rubber engine mounts are a few quid per side from Rimmer Bros etc.
I have a spare set of the ones shown in the first pic that I don't need ... PM me if you are interested, how does £20 posted sound?
3xpendable
PM sent
I hope that boat on your footer has atleast one V8 engine in it!
Best regrads
mgrv8
Post by mgrv8 »
I have mgb v8 engine mount brackets.... {the ones in your first pic are conversion type ..... one set would put the engine set further back in the chassis ,, look at the center line of the ruber mount to the other set..../ the second pic are mgb gt v8 OE type) i think i have both types......Steve
You need to know what ones you need,, and also what exhaust manifolds your using as you can set the engine lower in the chassis if your going to use MGRV8 ones :)
3xpendable
kiwicar wrote:I hope that boat on your footer has atleast one V8 engine in it!
Best regrads
No she has 4 x straight 16 cylinder diesels ;)
mgrv8 wrote:I have mgb v8 engine mount brackets.... {the ones in your first pic are conversion type ..... one set would put the engine set further back in the chassis ,, look at the center line of the ruber mount to the other set..../ the second pic are mgb gt v8 OE type) i think i have both types......Steve
Thanks for that, i;ve bought the conversion set above, and intend using the block hugger manifolds.
