SU carb conversion ?
cornish rattler
Post by cornish rattler »
Hi guys
Would replacing the rover 1.75" su carbs for jaguar 2" su carbs give the engine better mpg.
graham
owner of a static caravan
in cornwall.
no probably not, unless the engine is very highly tuned, however if correctly set up they should be no worse, all this depends on condition of both carbs.
best regards
I did that mod, to get more top end power from a 4.6.
The carbs are a bit of a pig:
1. They are both the same 'hand', so you have to bugger about with the linkages a fair bit!
2. There is no choke mechanism
3. The float bowls hit the rocker covers, so you have to tilt the carbs a bit, then tilt the float bowls back to level.
4. You need to port the manifold.
5. You need to modify the inlets.
Have a look partway down here:
http://www.cowdery.org.uk/v8rebuild-08.php
