Basically, I know you can get conversion adapters, and in fact I found some here that are perfect, but they're in the states (second set down);
http://www.drivewire.com/make/cat/wheel-spacers/jeep/
But they are expensive! I was wondering if anyone knew a place here in the UK that could do a similar job?
My front hubs are custom and I'd like to keep them, and the rear end is an SD1 axel so would be expensive to change the half shafts, so adapters are the next best thing.
I've already found the wheels I want to use (Rota GTRs) which are available for most jap cars, but I'd be looking at 114.3PCD,
so the adapter needs to be 127PCD > 114.3PCD (both 5 stud).
Anyone help?!
