My TR7 came installed standard with the 2HA Salisbury axle which ive modified to take discs and im planning to 4 link it and tie it into the cage & install a plate diff. Im going to run an M62 BMW V8 (300hp/300lb ft) and a 3.45:1/3.9:1 Ratio to leave it sharp on hillclimbs etc.
But Ive found someone selling a 4HA ex works TR7 v8 Axle, it would be an ideal transplant for the back end for my car, it comes with Shafts & Salisbury LSD & in Triumph wheel PCD.
The CWP Ratio of the diff is unknown and from quick research i can only see that some ratios are available but at £600 for a new CWP
1. Are spares available for the 4HA Axle? LSD Units?
2. Should i battle on the with 2HA until i break it?
3. Is the Salisbury LSD Unit a plate type diff? can it be adjusted?
3. Have any of you guys any idea how much i should offer for the 4HA if i decide to go for it?
Thanks in advance for any advice.
Iain
