Bell housing cover
adamnreeves
Bell housing cover
RV8 - 2WD bell housing. Whats the cover at the bottom between the sump and the bell housing called? Where can I get one from?
adamnreeves
- russell_ram
adamnreeves
Yep, looked at that one and knew it wouldn't fit as no hole for the clutch is a giveaway.
Thanks Russell. Rimmers, noooo. I shall have to say FRC142 and no substitute!
russell_ram wrote:Don't buy either of those unless you have an auto - they won't fit. The aluminiun ones are for autos ONLY. You need a steel one - FRC142 £20 ish from Rimmers (Adams favourite shop!).
The fixing bolts are M6 if I remember correctly.
Russ
