Champion N12YC Plugs
BrenG
Post by BrenG »
I have been given a set of these -they have been used, just as a spare set to get my VDP EFi running as the ones in the car get wet with the cranking of the engine.
However, I have noticed that the electrode is longer than the Denso W20EPR-U plugs that I currently have in the car. I assume they should be ok as the person I got them off breaks engines / parts.
Any advice appreciated.
How much longer? it could be an issue!
DEVONMAN
Post by DEVONMAN »
Another question to add to Mike's.
Is it the threaded section that's longer or just the electrodes.
Denisl
BrenG
Post by BrenG »
Just the electrode - threaded portion is the same.
DEVONMAN
Post by DEVONMAN »
Unlikely to be a problem unless you have domed pistons.
However, these plugs would not ideally suit a tuned performance motor.
Denis
BrenG
Post by BrenG »
Will these be ok in a 9.75:1 compression engine? I believe the pistons are different.
