Figures: 1.7" inlet and 1.5" exchaust
Rover
Exchaust measured without tube/flange.We add only tube with our hands, made approx 10cfm more flow.
inlet exchaust
0.1" 61 63
0.2" 119 100
0.3" 155 135
0.4" 161 153
0.5" 166 141
0.6" 170 137
0.7" 171 136
Gas speed is optimal 250??? unit, dont know what?
Merlin
inlet exchaust without tube/flange
0.1" 61 60
0.2" 111 98
0.3" 160 129
0.4" 177 131
0.5" 176 131
0.6" 177 131
0.7" 177 ---
gas speed was poor over 300xxx unit,
Guy say´s that inlet port are too small, neen opened out to to approx 47x27mm, and that funny corner have to grind away gas speed almost 0 behind that corner, also shark edged have to grind away, made too mutch turbulance in flow figures vs my rover 100% stable readings..
Exchaust was quite poor vs my rover heads, He say that exchaust port might be slightly better if port roof is raised and modifield to look like STD rover port. Also exchaust port size is to small, need to open 40x27mm aproximately..
We made slightly magic with my rover exchaust port floor, we add some modeling clay in the floor, exchaust port flow figures rise approx 0.5-0.7"range 20cfm (0.7" lift 165cfm. Approx 2-3mm rising made huge difference..)
Guy say´s that if he need rover heads, he will buy set of STD rover heads, and slightly weld those exchaust and inlet port floor, they will flow lot of better..
So if my heads flow approx 166cfm with my cam witch has got maxium lift 12.7mm and made 381hp.. I don´t understand why my heads only flow approx 350hp? I always say, that flow bench figures is only some stupid numbers. We dont grind any material my heads, figures might be better if some material is grinded, but guy says that are very good indeed without flow bench porting.
Peter Burgess heads?
http://www.v8forum.co.uk/forum/viewtopi ... sc&start=0
My exchaust flow more and inlet less..
http://forum.britishv8.org/read.php?6,15718
allmost identical numbers as mine..
MEASURED 93mm BORE 96mm might made slightly better numbers?
