BRC LPG system elctrical woes?
Rudy
Post by Rudy »
Hi everyone :)
New to this forum and hoping to get some much appreciated help.
I have a Lexus Ls400 with a BRC system. Recently the fuel level indicator lights have been going out every time I hit a bump or pothole. Then slowly come back on 1 by 1 and it switches over to LPG again until the next bump....
I suspect a dodgy connection somewhere. Anyone know where I can start looking?
Rudy
There'll be a sender on the tank, with two wires (probably green and black). The black one can be grounded anywhere from near the tank (the tank itself shouldn't be used as ground!!), and the green one will run to the front end somewhere.
Check them out.
Rudy
Post by Rudy »
Thanks for that Chris.
I'll have a look in the morning.
Do you happen to know if the car actually switches back to petrol when the lights go out, or it's just the lights being funny?
Rudy
softdash3.9
Post by softdash3.9 »
Some lpg systems can be programmed to switch to petrol when the tank is low, I could do this with my system (Bigas) on my range rover classic, but it was a pain as it would switch over and back to lpg with the gas sloshing about in the tank, so I disabled the feature.
Would think you have a wiring/short issue or defective level switch.
The low level switch is (in my case) a reed switch & magnet
Regards
Royston
Rudy
Post by Rudy »
I don't think it's the level switch. When driving on a road with no bumps, holes etc. it's perfectly fine.
Rudy
Rudy
Post by Rudy »
update:
I have unplugged and plugged back various connections, took it for a 60 mile round trip this morning, and the issue was gone. Hopefully it was just a dodgy connection somewhere and reseating several plugs etc has fixed it.....
Rudy
Return to “LPG Section”
