JP.
Post by JP. »
That Caltrac looks neat. Do you have any part numbers of that or was it re-made to fit.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
go to there website mate
www.calvertracing.com
go to the caltrac page and download the sheet, :wink:
JP.
Post by JP. »
So you must have the specs to fill in on the form....... :wink:
Building a GT40 mk2
im using a different axle set up aint I lol,
im using the mustang axle, only bits that may help are the bars and front bush size lol
Front of the car is apart for the last time prior to paint,
Cutting the lower grill area out and moving the oil coolers forward another inch, which will allow me to fit the two slim line pusher fans againt the inter cooler to help the rad fans cooling the rad in the summer if need be,
rather do it now and be safe rather than wait to the summer and it over heats and has been painted,
Also as planned while the rad is out the top corner opposite the top hose we are fitting a 10mm bleed pipe which will go back to the header tank as per the Audi rad we were using, to make any air trapped vents back to the header tank and not trapped in the engine etc, :D
Update,
front cut out,
oil coolers moved,
helper fans on intercooler,
all back in and car now running again, and the helper fans are helping pull the temp down and turn the fans on and off while in the garage,
a little vid of the car running, god have missed not driving the car lol
topcatcustom
Post by topcatcustom »
Exceptionally tidy as usual Tony, looks great!
TC
Thanks mate
What size filter is that?
Regards,
Will measure it later for you mate,
It is a JR filter can't remember the part number though,
Ta :)
The new rad is enroute to me :D
They always look great when shiny and new !
Finally got round to dropping the axle out of the Capri to check the backlash put the dial gauge on and mine reads 14thou book says 8 to 10 thou little shim swapping from side to side needed me thinks lol
just add a handful of sawdust to the oil and turn the radio up you will be fine :D
best regards
