yeah im going to wasted spark this year Dave.
BUT for now will order a new retard unit so i can eliminate that from the equasion,
it could be this that is causing the problems, as we got it to idle when we moved the base plate round.
any one local to Newbury who has a mallory vac advance unit i can borrow to test my car?
mines on order and will not be here until next week now.
- ihatesissycars
i want to run it with another vac unit gav, as want to see if it runs ok with it on again,
just to be safe as thats how it will be set up when my unit gets here,
has every one got the same mallory fault?
v8 tuner, Real steel and a few others all out of stock of the vac advance units, and all awaiting delivery
maybe im not meant to driver the car, just look at it in the garage,
spose its cheaper
spose its cheaper
- ihatesissycars
You could've put some coil packs on it or gutted a dizzy and run it thru that by now!
Why not get started on that route? I have a pressed steel 36-1 wheel you can have (for now't) then all you have to do is thieve some coils from a scrappie and away you go!
Flogging the mallory bits will get you a decent amount of money back for the mods you've just done too.
may have a point there Gav,
- ihatesissycars
if its not to far out of the way mate,
or we could meet some where if im in the oposite direction to where you are going?
- ihatesissycars
pm sent gav
- ihatesissycars
i gather today was a no go gav?
well phoned another 4 v8 parts places from the net today and they also had no mallory vac advance units
- ihatesissycars
