Rover V8 Engine Numbers Updated:
RV8 engine numbers
I have two RV8's in my garage and I need to find out some details for the them to satisfy the IVA man. Does anyone know what details I will need or do you guys/gals have any references to the following engines
17005781B
S10A44028
Thanks muchly
17005781B
S10A44028
Thanks muchly
alastair_vns
Without a photo I am only guessing - there are only two round identifications that I am aware of
If its cast into the block then its the date identifier - year in the middle and then an arrow showing the month on the clock face around the outside.
If its stamped then then only one I have seen is the BL Symbol
alastair_vns wrote:Hi I have 2 symbols on each side of my numbers what are they? they look like wheels.
thanks Alastair
4.5L V8 Ginetta G27
alastair_vns
I am afraid not, the best you could do is possibly tell whether it is a P6 or not but even that is doubtful. Without an engine number your kinda stuck with what the engine capacity is and a few other ways to narrow it down to whether it is a 4x4, P6 lump if its a 3.5alastair_vns wrote:Hi thats the symbols the numbers inbetween the 2 symbols are badly scratched tho so cant find what engine it is. Is there away of telling what engine it is from the exhaust port sizes? thanks
Any one know what this is out of?
Just wondering what the engine in the manta was out of.
Looks to have a p6 timing case with p6 rockercovers and a sd1 front pulley
I thought it was p6 but i think it may be sd1 the number is 10a37187
Can't seems to see it in the list.
Derek
Derek
Rust rust and more rust
I had a look on one of the RV8 engines I have kicking around today and wonders if anyone can help med with identifying it...
it has 9,35:1 CR
enginenumber under the left head says 56D22214A
On the engineblocks side, behind the starter engine I found these WYF15 and HRC2411 and behind the flywheel it is a letter J
Under the rockercovers I find the numbers HRC 2479 and I4
it also has bolts for the mains through the sides of the engine block and some kind of mountingbracket welded in behind the flywheel on the opposite of the starter engine
the heads also uses less bolts than the other engines I have.
Thanks guys
Sven
it has 9,35:1 CR
Thanks guys
Sven
- NorthernBloke
- Helpful or Confused
