All good possible things, but the noise only appears on 500s and the things you mention would also apply to the smaller engines TVR did.DEVONMAN wrote:I think we should try and eliminate a few items from the equation in an attempt to find the cause of the noise.
Lets start with the dizzy.
Has anyone got the noise on a 500 engine that has been converted to crank trigger? If so then the dizzy is out of the equation and therefore forget the following.
Grasping at straws, my thoughts on the dizzy !!!!
Did TVR fit lighter advance springs in the 500 dizzy to give greater initial advance? Weights may rattle at 1200 -1400 rpm.
Slim argument I know but possible as the cam pulsing may chatter the dizzy drive at these revs.
Second thought, It it possible that TVR do not remove the oil pump drive toggle an the dizzy shaft when installing a dizzy in a serp engine.
Cheers Denis
I think the severe cam, piston slap and pin to piston fit possibilities are 500 specific.
