Hi Mark,mgbloke wrote:More feedback.
Today I fitted 83jets with 65/52 rods with silver springs and 92 secondaries.
Briefly drove the car and it was immediateley apparent that there was a big flat spot coming onto part throttle. Once the engine picked up again it felt good. AFR was around 16 on cruise and flicked to 18 momentaerily as the engine stumbled before going back to around 15.
Didnt try WOT for obvious reasons.
Going to try same setup with 62/52 rods when the rain stops.
Mark
Your AFR figures are certainly showing that its too lean on cruise, I guess this just goes to show that not all engines are going to run the same carb setup in order to get the same AFR readings. My tests have shown that these lumps really don't run well once the cruise goes past 15:1 (when running a carb), It will stumble badly on 16:1 and 18:1 is just fresh air as far as the engine is concerned, it won't even manage to light the mixture!
Your 83 jet with a 65 cruise is 16% leaner than base, if you stick in a 62 rod it will be 4% leaner than base. I would have thought that something in-between would be required in order to give you 14.5-15:1 on cruise.
Maybe the 86 jet with a 67 cruise rod is what is needed? Of course once you have the cruise setup you then have to find a rod that keeps the cruise percentage right whilst giving you around 12.5:1 on acceleration, this can be tricky! (Just noticed that the 86 67-55 rod is what you started with!...Oh well you might be able to go a bit leaner on cruise than this!)
I think that to 'a degree' the different carb setups are required because of the different amounts of vacuum that different engines might pull even under the same cruise conditions. Its worth using a vac gauge on the non-timed port so that you can judge when the rods are up or down. It helps to have someone else reading the AFR and the vac gauge so that you can just drive! With the silver springs get them to tell you to keep opening the throttle until the gauge reads around 5-8 inches, that way you will know the rods are up, they then need to read the AFR for the acceleration reading. Keep posting what you find!
Did I email you the spread sheet or was it someone else?
