but does any one know if the R154 box may bolt to any other toyota bellhousings? like a hilux one etc?????
reason i ask is if it does i maybe able to use a bellhousing from a 4wd conversion vehicle.
Bolting to the bellhousing and getting it to work are two different issues. If the bellhousing was designed for the Toyota R150, then it will physically bolt to the bellhousing, BUT, the R154's input shaft is LONGER than the one from the Toyota truck. You may have to fab a spacer to get it back in the proper orientation. If the bellhousing is from a 97 and later V6 truck, it would be alright as is. The 97 and later truck transmissions also got a longer input shaft.thev8kid wrote:i know this sounds weird,
