I have also improved the sealing of the motor box by adding a steel framework and will also add some bracing to the motor box.
I have also made a head mounting fixture - the tube is a bit big at the moment - diameter is 104mm - ideally the bore diameter needs to be withing 1mm of the actual - but a quick search of e-bay and I have found some 100mm OD 3mm wall clear Acrylic tubing - 94mm bore
Just waiting for the local nut and bolt supplier to open up so that I can get hold of the right fasteners to put it all together again.
Andrew
