mgbloke wrote:Sidecar
Really interested in this thread.
As Bish V8 says we have been using the calibration kit and have ended up with .086 jets and .067x.055 rods with the secondaries being 0.092. Which seems to be about right for best power according to the Innovate.
However I have recently stripped my engine down and was surprised to find that the carbon buildup was not what I would expect. Instead of being hard and well baked on, the deposits are more like tar. You would expect to have to scrape it off but I could wipe 30% off with a rag. This must mean that my mixture is way too rich.
I have ordered the 0.083 jets and 0.065x0.047 metering rods to give them a try. It seems quite a big jump from 0.092 secondaries down to 0.083 but you have obviously spent a lot of time on this.
I will give it a go and report back.
Mark
Hi Mark,
Thanks for the reply, you know that I used to say that the jetting seemed to be similar for all RV8 engines and that is what I've quoted on the "How to build a Sumo (Cobra) wiki" site but I no longer think that, I must change the contents of the site one day!
Anyway Muscle Manta and I were working on a another 4.6 in a Lambo replica the other day, I don't know the spec of the engine but the jetting was not the same as my car or Mr. Muscle's.
The Lambo ended up with the pilots out 2.5 turns, silver rod springs, 65-47 rods, 83 primaries and 98 secondaries. That lot gave the following figures:-
Idle=12.5-13:1, cruise=14.5-15:1 Acceleration=11.5:1 WOT=12-12.8:1
We also noticed that the throttle had to be open quite a long way before the vacuum dropped enough for the silver springs to lift the rods, you should bear this in mind if you still have the standard springs as they are weaker than the silver ones.. The above setup is just about as lean as the cruise can go, as soon as 15.5:1 flickers up on the LC1 the throttle response goes very bad in my experience! (With a carb, I'm sure that you could go leaner on cruise with EFI)
The acceleration is a bit rich as is the WOT, 95 secondaries placed the WOT at 13:1 which is getting just a touch lean (12.8-13:1 being ideal)
We are going to try 83 primaries with 65-52 rods, this will leave the cruise at 16% leaner than base but rather than the acceleration being 0% leaner it will be about 10% leaner than base, hopefully this will get the acceleration to around 12.5:1. Also the WOT should lean off a touch even with the 98 jets, hopefully this will be around 12.5-13:1.
Really an LC1 or something similar is the way to go when setting up one of these carbs, I reckon you can get it done in a day if you have all of the jets and rods!
BTW, Muscle Manta can supply, jets, rods, and springs for a good price!
I guess the other thing to bear in mind that if you are only using your car on the track (drag racing?) then really only the acceleration and WOT figures are going to be important, the cruise does not need to be as lean as possible but there is no point in running it rich either!
Pete
