what's the best v8 to buy value for money
Why would you want to use anything else? The Audi box is cheap, it fits the Audi V8, there's a bellhousing adapter available for the Bmw V12, it's 6 speed, strong, Quaife do an LSD for it, the output shafts are in the right place, an Mr2 turbo driveshaft bolts to it without mods, the list goes on...
Honestly, why would you use anything else?
You could use a Porsche transaxle at more cost and more fabrication work, or a renault box with again a lot of hassle, but you're just making work for yourself for no reason.... the Audi box fits the Audi V8= no brainer.
You need to do some research into the Audi V8 and Bmw v12 in my opinion.
well cheers for the advice as i have said im building this to see if i can it will take along time but that will be the enjoyment next on the list will be the the suspension , brakes and changing the wheel base set up so it will handle more like the real thing even tho i know its fake but hay im just looking forward to learning how to build it
thanks all for your help
I have read through this thread with interest as i am doing a V8 conversion allbeit on a FWD Cougar
I am not sure what your budget is for the total build but to give you a little idea I have spent £6,000 plus so far on my car and i still have the engine,gearbox and driveshafts to get aswell as an ecu and he wires to create a bespoke loom. Due to the extra torque i have had to upgrade my suspension, front and rear ARB's, I have had to fabricate new mounts ready for the engine and gearbox, I am looking at spending another £3,000 just for the engine, another £1,500 for the gearbox and i still have to price up a quaiffe diff. All in all I have set myself a budget of £20,000 and think it will be hard to keep inside that.
Best of luck with your build, just dont think its a simple case of swapping the engine and gearbox over else your build will bite you
There is no replacement for displacement
