It's a bit late of a reply now, but my idle is more than happy at 800 - 830.BenL wrote:The air temp sensor in the plenum giving a false reading wasn't something I thought about at the time. I think it usually reads up to about 70deg but it isn't something I have really checked at this stage.
Wouldn't be too much trouble to move it though. Where did you site yours?
By the way what is idle quality like at 800rpm?
I set it to run at about this using the idle adjust screw on the plenum.
But i also run a 2 wire bosch idle control valve (instead of the stepper motor). With this it is set to idle faster at warmup - it hunts around a little bit when started till it knows what it's doing. It will hold my 830 when i have a load on the engine (i run a hydraulic pump directly off the front of the crank). *IF* i wanted, i could just type into megatune to change either idle speed and it's more than happy to do it. This is how i was shown to setup my MS, so i've not argued and followed their advice
My IAT sender is in a pipe before the plenum which doesn't really heat up.
Regards
Gordon
[/img]
