No noi, Lifters will be new!!CastleMGBV8 wrote:Don't forget to fit new lifters with the new cam and use the special lube and run it for 20 mins at 2000 - 2500 RPM without letting it idle, if it get too hot then shut it down and run again once it's cooled down, others have suggested spraying the rad with cold water helps keep it cool.
Can they use the single valve springs from the piper or do these have to be replaced?
As I understand the des Hammil Book right, the pipers are not that much stronger than the original Rover ones.
Schumacher ( a guy like a tree from Germany ) told me, that´they run in a cam for 1/2 hour at 2500-3000 rpm with special run in ube.
Should be o.k.!
Thanx!!
