help diff isues
chodjinn
Post by chodjinn »
A standard rover diff should also be able to cope witht he power for a 4.2 easily, even in the heavy SD1, using the right oil etc.
Standard diff and standard gearbox from the looks of things. That watts linkage doesn't look right either, the pivot is supposed to be vertical isn't it? The rods are at quite a steep angle.
bones
Post by bones »
Ive had alook and cant find TKC0108 anywhere, but TKC is the letters used for sd1 and truimph dolomite , do you know what the ratio is of the c,w,p ?. some long burnouts can cause that problem i believe, :) rich
Monster V8
Post by Monster V8 »
ian.stewart wrote:Thats just a standard open diff, nowt special there,
The question has to be asked, -------What the fec were you doing to cause so much damage, Rover diffs are a strong unit, and I have never seen a flange shear off like that, :D :D :D
I was turning left from a stand still at a junction then bang no drive at all, honest officer. :lol:
Monster V8
bones wrote:Ive had alook and cant find TKC0108 anywhere, but TKC is the letters used for sd1 and truimph dolomite , do you know what the ratio is of the c,w,p ?. some long burnouts can cause that problem i believe, :) rich
some long burnouts can cause that problem i believe, :) rich[/quote] :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Monster V8
Hi All
I need some more advice...... :?
I have agreed that I am going to get the quaife £495 diff from the gear box man.
But the problem is that the standard sd1 gear box can be rebuilt for around £450 But this would be standard sd1 rebuild.
I have been told that the T5 Sierra Cosworth gear box with the rover v8 to Cosworth gear box bell housing will go straight onto the engine and the gear stick will come up in the right place. Is this true?
The TVR V8 gearbox with the TVR V8 bell housing will work with my engine but…. Where the gear stick comes up is not in the right place… Is this true?
If anyone does know this, please can I have some advice as I’m not sure whether I should get the SD1 gearbox rebuilt or go for the TVR or Sierra Cosworth.
If you have any experience or knowledge on this, your advice would be greatly appreciated. :D
bones
Post by bones »
there are adaptors for those boxes, loads of people on here have different boxes some one will know, :) rich
Post by ian.stewart »
Cosworth T5 would probably work, IIRC TVR T5s have the lever far forward of an ideal position, Real steel sell a bellhousing if you dont want to look for a TVR one, T5s come in a multitude of types, last count about 250 variants
Monster V8
Just wanted to say thanks to all for your advice and help she now has a new
quaiffe diff
crown wheel and pinion
Gear box rebuild
working great 8-)
bones
Post by bones »
glad to hear its soughted, so burn outs are back on the menu, :) rich
