Yep, only by-pass is via cabin heater and when that’s off it makes no difference.
Fan is turning correctly and sucking well. At second stage it actually blows into the engine bay cold air so that part of rad is being cooled almost 100% as earlier posts.
I’m really certain the belt is not slipping as there is no sign of it doing so.
If I remove filler plug from rad water comes out, and will also from my new bleed valve if water is warm (expansion pressure). When cold it’s full to brim so no air locks IMHO.
I just can’t believe it’s the pump, somehow.
No other Dax with same radiator as this was designed to maximise cooling(!) as I spent a long time with several rad manufacturers to get it right. Most Dax Rushes use the Dax radiator which is an ali version of a Cortina rad with a pusher fan.
I’m using the MegaSquirt temp sensor that I calibrated - cold, medium and boiling water - and checked with my multi-meter so I know things are accurate here.
It’s Dax Rush (se7en)
Rad height 310mm, width 465mm and core depth 65mm – short, stubby and fat to fit nose cone more or less exactly. Fan is actually 320mm dia and is high capacity at 1,850 CFM so huge capacity.
I have flared side panels so have a very big escape route for hot air.
Now, Ian, your suggestion on making a shroud is exactly what I may try next. However I am unlikely to be able to do it with this high speed fan but should be able to do it with my previous 950 CFM fan as there is no room. Because of how most Dax Rushes are cooled (above) they have fans spanning most of the width so there is very little hot area not at least partially cooled as the fan more or less spans the width of the radiator. In my case 30% is not cooled and I am just wondering is this is the problem.
