Rad Fans?
Assuming your MS is reading the actual temp - ie no air pockets etc - I'd measure the rad where the fan switch is using an infra red thermometer.
Water is funny stuff - you can have a big temperature differential within a very close distance, if the water is still. Think of a domestic hot water cylinder - can be piping hot at the top, stone cold at the bottom. Now pumping the water round should equalize this - but there could still be pockets of air, or parts of the coolant that don't move much. And if the sensor sits in one of these, it won't give an average reading.
like I said its been faultless until the cooler was fitted,
Any one using MS2 V3 to run a cooling fan via the fiddlewire?
Some questions to help clarify things.
-Do the fans switch off at some point as the engine cools?
-Is it a 2 pin fan switch?
-Does the fan switch provide an earth to the relays or 12v?
-What is the Contact rating of the fan relays? (Cossie fans eat light weight relays)
- Are the fan switches you are using normally used in a plastic rad tank and not an aluminium tank.
-What position is the fan switch in the rad?
- If you disconnect the fan switch do the fans stop?
Think any of the spare ports can be used, although you may have to add a transistor driver for the relay. Although I'm not well up in the v3.57 board - prefer the V3 myself.Coops wrote:like I said its been faultless until the cooler was fitted,
The obvious one to use, if not already in use, would be the Fidle, since that has an output stage to drive a relay.
"DEVONMAN"]Some questions to help clarify things.
-Do the fans switch off at some point as the engine cools? YES
-Is it a 2 pin fan switch? YES
-Does the fan switch provide an earth to the relays or 12v? EARTH
-What is the Contact rating of the fan relays? (Cossie fans eat light weight relays) 40AMPS EACH
- Are the fan switches you are using normally used in a plastic rad tank and not an aluminium tank. PLASTIC AS PER FACTORY
-What position is the fan switch in the rad? FACTORY POSITION NEAR THE BOTTOM NEAR THE BOTTOM HOSE
- If you disconnect the fan switch do the fans stop? YES
Interesting. The factory one on my SD1 is just down from the top (crossflow rad) On the other side from both the hoses.Coops wrote:"DEVONMAN"]Some questions to help clarify things.
This is a factory Audi rad that I have used for years
yeah its correct mate lol,
just got the wiring details through, so off out in the garage in a bit to wire up the fans to the ecu and put the settings into the ecu to trigger it
yeah it is mate earth trigger wire to relay
- richardpope50
- Gold Member
... but the best place is in the rad output hose at the bottom as then it is sensing the actual cooled water temp and adding the fan if the rad is not cooling enough.stevieturbo wrote:Normally a fan switch would be towards the top of the radiator ? Or in the top hose itself ?
Richard.
The MS ecu is now coupled up to the cooling fan relay, and the car is sat happy just over half on temp gauge,
fans set to come on at 90C go off at 88C that sound ok temp wise for the fans???
You ultimately want to cool the engine. Water temp coming out of the rad is less important unless it isnt sufficiently cold to cool the engine.richardpope50 wrote:... but the best place is in the rad output hose at the bottom as then it is sensing the actual cooled water temp and adding the fan if the rad is not cooling enough.stevieturbo wrote:Normally a fan switch would be towards the top of the radiator ? Or in the top hose itself ?
But as long as engine cooling is kept in check, that's all that matters.
That will depend on your normal engine running temperature. What does it sit at when cruising at say 50-60mph ?Coops wrote:The MS ecu is now coupled up to the cooling fan relay, and the car is sat happy just over half on temp gauge,
Then set the fan to come on maybe 3-5 degrees above that temperature and then of 2-3 below your chosen temperature.
stevieturbo wrote:Stevierichardpope50 wrote:[quote="stevieturbo"
That is interesting as I was advised the opposite.
Give the car a quick blast and the water entering the rad may spike upwards. Why would you at that stage want the fan to come on? You may be going at 40 mph and the normal airflow will do the job.
Now position the switch near the outlet and that spike will not be seen, the fans not turn on etc.
the only time you need the fan to be on is when the water exiting the rad is getting too hot and hence needs cooled
