seight wrote:![]()
He's got you going now Tony!
It was so easy.
smoke on over run :-(
bugger
Tony, these are the pistons I am using, with 4.6 rods the comp is around 11.1, and 4.0 rods its around 13.9,
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
They are not handed, so you can guess they are going to be slappy, and the Rods need to be bushed 22 to 24mm
Ta Ian,
will have to wait though as spent enough last/this year and done nowt really,
once money comes available again will look into these, cheers mate.
- Rossco
- Moderator Gold
There are plenty of Chevy piston and rod combos that will do the job.
Rather than bush Rover rods use small journal Chevy rods and you then have the choice of all the low price after-market H and I beam rods......good for 700bhp and more.
All you need to do is have the width of the big ends reduced. Off the top of my head it's 50 thou each side then have the chamfer reground. Here's an example
http://www.cnc-motorsports.com/product. ... CtgID=8183
The 305 chevy pistons are 3.736" bore. . . so .36" overbore, chevy rods need the sides machined as said but there is a wide choice of rods and as Ian said you need to turn down the big ends on the crank .1", if off set ground that is an extra 1.25 mm stroke fiddly but there are a wider choice of forged pistons at sensible prices.
Had a call from Ray today,
the new rods and pins dont seem to be that tight a fit when he put them in the press,
he is going to do a test next week to see how much pressure moves them,
God please dont say these are fooked as well
Otherwise it looks like i may end up having the engine back in the next week or more,
Tony,thev8kid wrote:Had a call from Ray today,
God please dont say these are fooked as well![]()
You can't be that unlucky twice.
Maybe it's a 1st April wind up.
Cheers Denis
Hi Denis,
hope it is a wind up mate.
Im still thinking about this route if the pins and rods aint 100% i have at v8 d now,ian.stewart wrote:Tony, these are the pistons I am using, with 4.6 rods the comp is around 11.1, and 4.0 rods its around 13.9,
do they do a version of this forged piston with valve reliefs???
Can you not machine in a circlip groove?
They'll never move then
Or teflon button ends on the gudgon pins
Just got off the phone with Ray,
looks like the new rods and pins are ok, PHEW!!!!
should have fingers crossed it all back here end next week,
block top hatted,
and bottom end all lightened and balanced
Looks like im gona need them parts from RS soon Pel
block top hatted,
